Garage door 16’
Garage door 16’
I need help with what beam to install or how I can make one for a 16’ garage door. I moved my garage door from one wall to another and need help on how to install a beam. The wall is not load bearing and will just have the door. Thanks in advance
A double 2x12 header is typically the minimum header for a 16 ft opening. It needs to be 9" longer than your finished opening size, and needs 2 king studs and 3 trimmers on each side. If it was a load bearing wall you would likely want to use a taller LVL instead of a 2x12, sized for the load it needs to handle. (Different in each situation)
Info
Sorry for my terminology but yes was talking about the header that’s what I was referring to by beam. My was is made of 2 x 6 and it’s not a load bearing wall. I will attach pictures of what I have. It’s was installed how it shows on the first pic but moving it to how it to the other wall where there is no opening yet
This is how I have it now on a load bearing wall
It’s going ok that not load bearing wall
No. You would buy LVL. And you have not provided enough of a blueprint for us to just rubber stamp your plan.
Did three 2 x 12 x 17
Ended up doing 3 2 x 12 x 17 with 2 rows of OSB sandwiched in. I did it this way so it would fit better with my 2 x 6’s going to use to king studs and 3 trimmers on each side but omg this thing is heavy. Now trying to figure out how to get that up there since I have to nail the king studs to the header Before putting it up due to the space.
See table r602.3(1) line 27 for the nailing schedule for fastening built up beams together.
Example of code.
Example of code.
Huh? You follow the nailing schedule linked above, for your triple layer beam it would need 20d nails staggered from each side, alternating at 32" on center top and bottom.
Any outside wall is load bearing.
