Stairlift DIY Installation
Old 04-14-22, 09:12 AM
E
I would like to get input stairlift DIY installation and a recommendation of brand that you have had experience. I'll understand some members don't like to mention brands, but any info on specs or details would be of help, This is for a straight stairs, 13 steps and 13 ft 6 in.
I rather not do a pro install at this time, but if you had experience with this I would appreciate any pointers.
Old 04-14-22, 09:51 AM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
I've only done one... a r/r (remove and replace) and it was a Bruno Elite. Wasn't too hard. Biggest problem you will have is getting them to sell you the kit without their installation. The dealer will want to ensure it's installed properly and get service behind the sale, etc.
Old 04-14-22, 10:06 AM
Received 3,596 Upvotes on 3,225 Posts
I've removed several. I've installed two.... Bruno SRE-3000's.
You need to be handy and follow directions closely.
You can find them used on ebay, craigs list and probably FB sellers market.
Expect to replace the batteries on any used unit.
If it's only needed for a limited time... some companies will install and buy back after use.
Look into that too.
Old 04-14-22, 10:22 AM
E
Any problems getting replacements parts for DIY installed units ? I know batteries are usually standard sizes, so that should not be an issue. I have carpeted stairs. Do the install instructions give the screw size and type for the mounting brackets/feet?
Old 04-14-22, 10:46 AM
I wouldn't necessarily call the Bruno units "DIY".
It may be difficult to buy outright as most of their sales are to dealers.
The batteries are sealed lead acid and can be obtained many places.
I haven't needed any parts from Bruno yet.
Was looking around and found this..... Ameriglide DIY systems
Old 04-14-22, 11:38 AM
E
Thanks for the link. I'll check it out.
Old 04-18-22, 07:31 AM
E
Any experience with the chair swivel feature for the top of the stairs, especially between manual and motorized ? Would seem to be a necessity, at least for my application.
Old 04-18-22, 07:37 AM
W
Received 61 Upvotes on 53 Posts
We have a Bruno. The chair swivel is manual. Very pleased with this arrangement.
PJmax voted this post useful.
