2x4 framing turned "sideways"
Old 05-22-22, 01:10 PM
V
Hello, my entire house was built in the 1950s with the 2x4s all turned sideways.
I am trying to replace all the interior doors but standard door jambs wont work. Will i have to custom build the door jambs?
Any input would help!
Image to see what i am working with.
Old 05-22-22, 01:17 PM
Received 785 Upvotes on 688 Posts
The only way to use a normal prehung would be to build the wall out. It's possible a mobile home supply would have prehungs to fit 2x2 framing. Could you just buy slabs and reuse your existing jambs?
Old 05-22-22, 03:13 PM
V
The old jambs are metal and new hardware doesn't work, also there is no way to hang trim traditionally around door frame.
