Filler for uneven floor under new vinyl plank.
Old 06-09-22, 06:54 AM
D
Hello.
I'm going to be installing a new coretec vinyl plank fake wood floor in my kitchen. I recently moved my island in the kitchen and cut out the peeling linoleum from around the island. I also made a channel for an electric wire to connect under my Island. I'm guessing this needs to be filled and leveled out so that it's even with the existing linoleum. A little bit of Google and I came up with feather finish cement based filler. I never used it before but I'm just wondering how well it will stick to a different surfaces that are needing to be filled. Also the channel for my electric wire is about a half-inch deep.
will feather finish Bond and not break apart over time underneath the new vinyl plank floor? I was also thinking maybe I could use Bondo Filler instead of feather finish.
when I fill the electric wire Channel I was planning on stapling the wire to the subfloor to secure the wire.
does anybody have any thoughts for tips?
Old 06-09-22, 07:01 AM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
I don't think you'll have any problems. The area will be covered and will not see any stress from traffic.
Old 06-09-22, 07:08 AM
D
Are you saying you wouldn't even bother with a filler? I am kinda set on using filler. Just was unsure what'd be stronger without breaking over time. It is a low traffic area but still thought it should be filled. Incase it lines up with the edge of a plank or something funny like that. Thanks for your reply.
Old 06-09-22, 07:19 AM
Norm201's Avatar
If it was me I would not fill it in. But no harm if you did.
Old 06-09-22, 08:12 AM
D
If you were to use a filler. Would you think bondo or feather finish would be less prone to cracking under the flooring?
Old 06-09-22, 10:57 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Hmmm, not sure having that electrical wire under the flooring is good, someone else will chime in, but if me, I would move it so it came up in the cabinet!
Norm201 voted this post useful.
Old 06-09-22, 11:39 AM
D
It does come up inside the cabinet. It's just that the cabinet used to be over top of where the wire was so it didn't need the channel but since I moved the base cabinet I channeled it out so the wire is below grade of the floor. What problem do you foresee with the wire
Old 06-24-22, 10:18 AM
D
Does anyone else see any issue with covering the wiring with a filler and covering with flooring? I think that's my plan now
Old 06-24-22, 11:20 AM
Norm201's Avatar
Only when and if you need to do electrical repair!
askari voted this post useful.
Old 06-24-22, 01:00 PM
D
Gotcha. I'm confident in the electrical situation and believe repair won't be necessary but either way the floor sits on a slab so I'm betting all that it'll work out. Thanks
Old 06-24-22, 03:07 PM
Marq1's Avatar
And there is a future posting, why would somebody have done this!
Old 06-24-22, 04:08 PM
Norm201's Avatar
There is no need to imbed the electrical wire in and kind of filler. In fact you want the electrical wire to have some give for if and when you need to move or service the unit.
Old 06-24-22, 04:41 PM
D
Haha mark, I hope that's not the case, but norm, I only wanna fill with filler because I want the vinyl planks to be on a solid surface. Or is it such a small spot that I can float the plank over it
Old 06-24-22, 05:00 PM
Norm201's Avatar
If the section will be completely covered and no traffic will hit it, then leave it! If it's exposed, then fill it.
