Non-load bearing wall
Old 06-18-22, 12:25 PM
nemery23e's Avatar
Received 1 Upvote on 1 Post
I what to make an interior wall. The wall would be placed in between two floor joists. The closest floor is joist is about 7 inches away.
Question: By code do I have to attach the top plate to the ceiling. I made about 9 or so blocks to bridge between the top plate 2 x 4 an a separate
2 x4 I attached to the closest floor joist. There is a wall stud I attached to and can nail in to a concrete slab. Pictures enclosed.
Old 06-18-22, 12:34 PM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
I'm only guessing, but I don't think it needs to be code. But for stability purposes I would think you'd want it anchored to the ceiling joist.
What youdid so far looks good. The only problem I see is blending in the ceiling with those extensions.
nemery23e voted this post useful.
Old 06-18-22, 12:41 PM
nemery23e's Avatar
I make the wood look like an old fashioned soffit. I Already put in a permit with San Antonio. When I finished my door rough opening I will give a call for approval.
Norm201 voted this post useful.
Old 06-18-22, 01:14 PM
Norm201's Avatar
I kind of thought that's what you would do. Personnaly I don't care for the look, but it will be nice.
Oh! I thought it was only going to be a divider walll as opposed to seperate room with a doorway. Again I don't know if it will make a difference but it might. You need to check with your local codes. And the enetrance door will need a fire break, which is typical.
Old 06-18-22, 01:50 PM
XSleeper's Avatar
Received 1,811 Upvotes on 1,628 Posts
For walls that are parallel to the ceiling joists and that happen to fall in between the joists, the top plates get nailed to blocking that has been installed between the joists. In your case you would add that blocking from inside the attic. (Assuming this is a 1 story house)
Old 06-18-22, 03:04 PM
nemery23e's Avatar
Two story home.Unless I tear down the sheet rock I would just move the wall.
