Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Metal Studs on 5 ft center need options to install paneling
Old 06-25-22, 09:01 AM
C
Newly constructed metal barn with all metal studs
Barn with apartment here |
, apartment side has 15 ft slanted ceiling, need options for making a flat ceiling, should we install wood beams around the top of the interior walls? With the option of storage. Hanging panel on 5 ft center studs, Should we just install wood studs or wood blocks for walls?
Old 06-25-22, 09:11 AM
P
Received 1,952 Upvotes on 1,748 Posts
I would frame out the living quarters within the steel building.
Old 06-25-22, 09:30 AM
C
Just wanted to keep the man amount of sq footage. Should we use 1bys.
Old 06-25-22, 10:52 AM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
Frame walls between your existing steel studs that are in line with your existing walls, with studs 16" on center. Put 5' long double top plates on these walls. Then, use the appropriate sized 2x ceiling joists (10# psf) or 2x floor joists (40# psf). The size of these joists is based on their span and the desired use/load.
badeyeben voted this post useful.
Old 06-26-22, 04:09 PM
B
Received 258 Upvotes on 230 Posts
Check with the local building inspector first so you don't end up being denied an occupancy permit.
