Will mortar cure to floor leveling compound?
Old 08-19-22, 04:25 AM
Received 3 Upvotes on 3 Posts
I need to set a fiberglass shower stall base, the floor is an 1/8" or so low in that corner. I'm going to use floor leveling compound to get this corner level, I also need to put mortar on top of the floor leveler to set the shower base. Will mortar cure to the floor leveling compound, I don't want this shower base to move..
Top Answer
08-19-22, 04:30 AM
XSleeper's Avatar
XSleeper
XSleeper is offline
Received 1,812 Upvotes on 1,629 Posts
Should be fine... but you really don't need to use floor leveller. When you mortar in the shower base, that's all the leveller you need. You will use a level as you settle the base down into the mortar.
Old 08-19-22, 04:30 AM
XSleeper's Avatar
marksr, Pilot Dane voted this post useful.
