Getting Out Screws w/o Head
Old 04-08-04, 07:13 AM
handyson
Hello, I'm fourteen, but I can do a lot of things around the house. We are preparing to move, and when we gave away our old computer I noticed that part of the desk would make a perfect guitar cabinet for my amplifier. So I set to removing the unneeded part. I've removed all of, except there are these screws coming in from the otherside that you can't get to the heads. I'll try to draw a diagram.
___
Old 04-08-04, 07:17 AM
C
There is a device called a screw extractor that is different from others in that it is a hollow cylinder with teeth on it. It is used to bore around the shaft of the screw and remove a core of wood with the screw inside it.
Check the larger hardware stores for this.
Hope this helps.
