Unfinished Oak Table
Old 12-09-05, 01:30 PM
123bear
Water Damage to an Unfinished Oak Table
I have a solid Oak Unfinished table that got wet & has some mold/mildew developing on it. How do I get rid of it? Thank You
Old 12-09-05, 02:14 PM
Unfinished, you'll have to be careful
First you have to kill the mold/mildew
If it's only a little, Lysol might work
If it's a bunch, you may want to use X-14, or a bleach/water 50/50 mix
After you've killed it, hopefully it will come off OK
Scraping , and perhaps sanding may be needed
You'll need a light touch with either, you don't want to grind any dead, black, mildew into the table
If it is a tenacious mildew that won't come off, some more fire power will be needed, but you will run the risk of affecting the wood
If it has water stains, then you'll want to sand it down anyway, and it's less of a problem if you need to get aggressive with the mold/mildew
Old 12-09-05, 03:25 PM
Received 94 Votes on 83 Posts
Sealing the wood after you get it cleaned up will go a long way to keep this from happening again.
Old 07-20-09, 12:13 AM
K
This is possibly a stupid question but how do you know when or if the mold is dead?
Old 07-21-09, 07:44 AM
George's Avatar
As per my reply to this same question in the carpentry/woodworking forum...
probably water marks, not mold.
Sanding will NOT remove watermarks
Oxalic acid is the answer - avilable at many hardware stores and big box stores.
