dresser draw bottoms falling out
Old 10-11-08, 12:04 PM
I
Unhappy dresser draw bottoms falling out
the bottoms of my dresser draws are fallling out. some of them have completely seperated from the draw(so i have nothing at the bottom of the draw ). what is the best way to fix this.
thanks for the help
Old 10-11-08, 12:24 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
There should be a groove all around that the bottom fits into? As things get older they open up the joints a bit.
A quick fix would probably be, turn the drawers upside down, press the bottom into the correct position and put a good bead of hot-melt glue in around the edge, to act as a bit of support. I've done it, and it will probably last quite a while. You need to hold the bottom until the glue completely hardens.
Better would be to get some thin 1/4 round or bead from your local Home Improvement center or Hardware store and wood glue and brad nail it to the sides, back, and front.
I've even had to add a support under larger drawer bottoms cause they were just too warped/bowed to stay in. Used hot glue for that as well. Still have some fixed that way.
Old 10-11-08, 02:41 PM
I
thank u. can u recommend any particular brand of glue?
Old 10-11-08, 02:59 PM
Gunguy45's Avatar
Super Moderator
Wel, hot glue requires a gun, and any general purpose sticks from the same place (craft stores, Wally World) should be fine.
Prob $5-7 for a small kit.
If you are going the bead and wood glue route, any of the yellow wood glues would work. They take a while to set up completely.....3-4 hrs at least...before using.
Old 10-14-08, 06:24 PM
U
Wood Glue is a better one. Have used Wood glue and it works great
