I separated the hutch from the buffet and am currently just using the buffet. I have been looking for a sideboard or a buffet for the cottage and then I remembered that I have the hutch in storage. I am wondering if I can turn it into a buffet? Can I cut off the backing and add legs? Thanks in advance for your advice !
Looks like you could do that easily. I have similar one and the construction looks conducive to cutting it down. You could just cut the sides and back to the height you want and not even have to add legs. The scalloped bottom edge might look weird but hey, it's a cottage. Can't tell in the photo but the same edge might be at the bottom of the buffet and look OK.
If the top is recessed by the crown (as mine is) you will need to add a top.
The top is flat so it should be okay and it does have the same edge as the bottom of the buffet.
Good point about the glass doors, I did not think of that and I have kids and 2 large dogs! The spot where I would like to put it is a low traffic area so I will see how it goes.
My recliner has four buttons. Two for the headrest and two for reclining. Once in a while the two for reclining stop working. If I disconnect power from the motor and re-connect power, the two reclining buttons work. Does this mean I need to replace the motor?
Thanks,
K-
I picked up a used good condition real relax massage chair that had air bags on it and even on low it squeezes so tight it hurts. Any idea what could be wrong or a way to rig it to not inflate so much?
