repairing broken chairs
Old 10-05-03, 06:33 PM
Mary Lou
I have at least eight chairs that are in need of repair. It seems that the legs came out of the holes and are very unsteady. I hate to throw them away, can you help?
Old 10-05-03, 08:26 PM
duane young
yes i can you lamper go outside and put them in the bin
Old 10-05-03, 08:42 PM
C
You can make the tenons larger by gluing some veneer or cardboard of the sort that cereal boxes are made from around them. You may need to sand them down or add to them to make them fit snug. That way, you can glue the tenons back into place.
Hope this helps.
Old 10-06-03, 08:03 PM
duane young
i have found that applying luncheon meat to each individual foot will prevent any unwanted scratching to your flooring
Old 10-07-03, 10:57 AM
brickeyee
I use shavings from a hand plane to build the diameter of round tenons back up. For any repair to work you need to remove all the old glue on both sides of the joint.
Old 10-11-03, 02:15 PM
duane young
also i have found that shavings from a one eyed hairy backed shek will also help as for glue i have found that pritt stick is a great substitute for many of the more expensive adhesives
Old 10-11-03, 05:49 PM
C
Pritt glue stick is a water-soluble, temporary adhesive for paper and paper products. It works well for adhering sheets of paper together temporarily.
Hope this helps.
