Lacquer finishing
Old 10-12-03, 03:57 PM
Petee
Lacquer finishing
Have a catalyzed lacquer kitchen table that a hot pot has left a blush, how do I remove it without stripping the table?
Old 10-12-03, 04:08 PM
C
You can remove the finish with a methylene chloride stripper.
Old 10-17-03, 10:24 AM
brickeyee
Try a dry towel and an iron on medium heat. You want to get the wood warm without scorching or softening the finish. A heating pad left over the spot for a few hours (sometimes days) can also move the moisture out of the finish. Works sometimes, not always. It depends on how far into the finish and the wood the moisture actually penetrated.
Old 10-17-03, 03:45 PM
fewalt's Avatar
Have you tried rubbing the spot/area with mayonnaise or toothpaste??
fred
