trim board
Old 06-22-04, 12:57 PM
trim board
How do I mitre a trim board that meets each other at a 135 degree angle? I need 2 mitres of 67.5 degrees each but my mitre saw only goes to 55 degrees?
Old 06-22-04, 01:20 PM
C
Miter off 22.5 degrees. Make a piece with a 45 degree miter and use it as a guide clamped to your table to hold the piece to remove a piece 22.5 degrees.
If this is an inside corner, just cope the joint and it will fit everytime, anyway.
Hope this helps.
