Edge Finishing for MDF
Old 11-05-04, 10:35 AM
G
Red face Edge Finishing for MDF
My daughter has asked me to cut new doors for her kitchen cupboards for which she wants to use 5/8" MDF. She intends to paint the doors and as she would like a clean look, would prefer not to use any edging whatsoever. My question is: Will the cut edges of MDF be smooth enough to permit a good finish with paint alone or will some sort of pre-filler be required? If so what do you recommend? Matt
Old 11-05-04, 01:59 PM
C
What I do is spray the edges with primer first and sand it down. It takes a couple of passes to fill the raw edges of the MDF, but is easier and cheaper than wood filler. You might also try sanding sealer, if you have some.
Old 11-05-04, 03:59 PM
G
Thanks Chris!
I hope that will do the trick! Matt
