Stripping circa 1900 doors
Old 12-30-99, 12:48 AM
Guest
Post
I purchased several old doors from a Victorian cottage. They have several layers of paint, varnish, lacquer, shellac and once again MORE paint. What is the most effective way to remove this mess? I am aware it is lead paint on the doors. I have also discovered some beautiful faux painting techniques under some of the layers, so I have decided to stop the stripping at that point. What would be the best way to clean and preserve this surface after it has been exposed?
Rena
Old 12-30-99, 10:11 AM
Guest
Post
Rena:
Here you have gone over the fine line between refinishing and restoration. Any good paint and varnish remover will get rid of the layers, but stopping the process at a certain point requires an expertise acquired from years of experience.
In other words, you need to take these doors to a professional restorer. Check with reliable antique dealers in your area, and then check the credentials of those restorers that are suggested. This is a project that doesn't allow for mistakes.
George T.
