painting headboards
Old 01-04-05, 12:38 PM
JEMx5
painting headboards
Hi I purchased two headboards with the intent to paint them white. They are currently a maple color. I have never done anyhting like this before and am not totally sure of what to do. I primed them with a spray paint primer and the sprayed them with a gloss spray paint. As they started to dry I noticed they have a cracked appearance in some areas and bubly look in other areas. Should I have sanded them first? Do you think if I keep adding coats that it will eventually be smooth? Wht should I do?
Old 01-04-05, 04:07 PM
Received 3 Upvotes on 2 Posts
Yes, you should have sanded them first
No, don't keep adding coats it won't help
This is happening because of improper surface preparation or incompatable finishes
Let them dry and then sand them as much as you can
Get down to the old finish if you can, and sand that some too
Then get out the brushes
Prime with a quality oil-based primer, your local paint shop may even have reccomondations for trouble projects like yours
You can top off with a quality oil or latex paint
If you want to use rattle cans, maybe someone will come along with suggestions, as I haven't found good success with them and wood
Old 01-08-05, 11:54 AM
JEMx5
Thank you for your help. I am currently sanding them. Do I need to get all the white off? Or is it ok if I leave some of it? Some of it is not coming off and I'm afraid of sanding too much. I have some coming off in chunck that is leaving the old finish showing. I bought some kilz odorless primer does this sound right?
JEMx5
