Cloudy Wood
Old 07-06-05, 02:03 PM
ConnieR
Cloudy Wood
Hello:
After stripping 6 layers of paint off an antique mahogany dresser, and washing the wood with mineral spirits, the wood appears cloudy.
What should I do to remove the cloudy appearance from the wood?
Connie
Old 07-07-05, 05:12 AM
George's Avatar
Sounds like the initial layer of paint has been dissolved and settled in the grain of the wood.
Mineral spirits (paint thinner) is not what I suggestfor a wash after stripping - wash it down again using 0000 steel wool and lacquer thinner; then wipe with clean rags and/or paper towels, again using lacquer thinner.
Old 07-07-05, 12:48 PM
RainieL
The cloudiness is most likely paint residue. Have you sanded it yet? After stripping a piece sanding is the next step. I know that will remove anything that is still on the wood before refinishing. Remember some tack cloths as well to remove the dust from sanding.
Hope this helps
Rainie
Old 07-28-05, 07:32 AM
ConnieR
Thumbs up
I want to thank you all for the help. The lacquer thinner worked great and the pieces look wonderful.
Thanks again
