Sanding Bullnosing
Sanding Bullnosing
I have taken on the task of refinishing the bar tables in my son rec room.
I need some advice on how to mechanically sand the bull-nosed edges of the tables.
The tables are 2 ft. in diameter (6.25 ft in circumference) and 1.5 in. thick.
and , if necessary, detachable from the stand.
Any ideas will be gratefully accepted.
Thanks
Thanks
Originally Posted by marksr
I would use a palm [or similiar] sander. Just make sure you keep it moving so all areas recieve the same amount of sanding
