door casing with rosettes
Old 04-29-06, 01:38 PM
do i put the casing up first or the rosettes up first?
Old 04-29-06, 03:47 PM
W
Received 31 Upvotes on 25 Posts
Install both side casings, then the rosettes, then the head casing.
Old 04-29-06, 09:22 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
It depends how you are fastening them. I used to biscuit join the corner blocks (rosettes) onto the ends of the head casing first... and installing that as one unit, and then cut the sides to length and glue them to the bottom of the corner block.
Lately I've enjoyed using pocket screws to fasten the entire casing together prior to nailing it up. It results in a flawless joint and less glue squeezeout.
http://pg.photos.yahoo.com/ph/thexsleeper/detail?.dir=4b29&.dnm=1781.jpg
and
http://pg.photos.yahoo.com/ph/thexsleeper/detail?.dir=4b29&.dnm=306d.jpg
