water stains
Old 10-16-06, 08:28 PM
T
water stains
what kind of acid takes care of this? I read something can't remember thanks
Old 10-16-06, 09:16 PM
XSleeper's Avatar
Received 1,710 Upvotes on 1,534 Posts
oxalic acid can remove some stains from certain types of bare wood- wood that does not have any finish applied.
If your wood has a finish, the water mark is in the finish, not the wood. This older thread might help with some ideas: http://forum.doityourself.com/showthread.php?t=276158
Old 10-17-06, 04:42 AM
George's Avatar
'Water marks' IN the finish show white. These can often be removed by a light sanding and/or steel wooling to remove the top layer of finish where the moisture has settled.
Water marks that have penetrated the finish and affected the wood show black. The piece must be stripped before using the oxalic acid.
Old 10-18-06, 03:36 AM
T
Thanks yes the wood is unfinished the stains are black
