glaze stained cabinets
Received 0 Votes
I would like to apply a glaze over stained oak cabinets. I was going to strip off the polyurethene and leave the stain (Minwax golden oak). These kitchen cabinets are 12 years old. Any ideas on the process of glazing over stain? I don't know what kind of glaze to use. I only want the glaze to appear in the corners and edges, not on the flat surfaces. I also don't know if I should put the new coats of polyurethene on before or after glazing. Thanks for your help.
Many glazes can be applied over existing finishes. Stripping the finish will remove part of the stain, which I assume you don't want.
The surface should be lightly sanded (220 grit) and the glaze applied in the areas you want. Use a dry brush to feather it out. If it's darker than you want, or not where you want, paint thinner on a rag will remove it.
After you have the look you want (shading, etc.) allow to dry (48 hours) then top coat with the poly of your choice of sheen
