Polyurathane
Old 05-16-07, 07:46 AM
L
Smile Polyurathane
How many coats of poly do I need to put on newly refinished kitchen cabinets? Thanks,Loralie
Old 05-16-07, 09:27 AM
the_tow_guy's Avatar
Received 264 Upvotes on 215 Posts
I generally use three coats of poly on my wood projects with a light sanding with very fine sandpaper between coats (make sure you get all the dust removed before all coats).
Old 05-16-07, 09:38 AM
Received 873 Upvotes on 764 Posts
Ya, it's hard to get a nice finish with less than 3 coats of poly. As TG mentioned, hand sand with 220 grit sandpaper [fine grit sanding sponges also work well] between coats and remove the dust.
