Best way to sand/refinish old cabinets
Old 01-01-08, 09:17 PM
I've removed from the wall an old upper kitchen cabinet. This is solid wood but real old. I stripped off layers of paint with a remover, filled low spots with a wood patch material, and have been trying to sand it smooth. This is taking a long time and I'm wondering if there is a better way to get this old uneven wood smooth and straight...would an electric planer be overkill?
I know this is a lot of work, but since I can't afford new cabinets, I'm trying to make this one look nicer.
Any suggestions for me?
jc
Old 01-01-08, 11:17 PM
Received 1,281 Upvotes on 1,219 Posts
An electric planer would probably remove material so quickly that you'd go too far before you knew it. I'd keep going the way you are. I find that sandpaper around a straight piece of 2x4" makes for a great sanding block to make sure everything's even.
Old 01-02-08, 06:50 AM
Received 871 Upvotes on 762 Posts
Are you sanding by hand? Most any palm sander would be a good choice. Start with a coarse grit where you need to remove a lot of material and finish sanding with a fine grit.
