polyurethane to stairs
Old 09-04-08, 10:09 PM
L
I have recently stained some stairs with an oil based product. The wood is doug. fir. I have worked with wood finishing before but I am concerned about a drip nightmare with the balusters. Should I very carfully brush or spray on a poly.? What is the industry standard?
Old 09-05-08, 04:00 AM
Drips/runs comes from applying too much finish. Just don't load up the brush, and keep the piece wiped evenly. Spray gives a better looking finish, but again, if you dwell in one spot, you will have runs.
Old 09-05-08, 04:05 AM
Received 857 Upvotes on 749 Posts
Welcome to the forums!
Overspray can be difficult to contain so I rarely ever do any spraying in an occupied dwelling. it usually takes 3 coats of poly to make wood look/feel right. With a little care there shouldn't be any issues with drips. Make sure you use a quality natural bristle brush.
You didn't say if this was new construction or if you stripped and refinishing installed staircase. On new construction, I like to stain and apply 1-2 coats of poly prior to installation - it makes the job a lot easier
