Mitre saw question
Old 12-02-08, 06:08 PM
C
Mitre saw question
After beginning to build some radiator covers and soon a dining table, I bought an entry-level mitre saw, a cheap Ryobi 10". I put it together and it seems to be solid, its got a laser and all the fixings, but it doesn't slide.
Question is, am I really limited to cutting only 2X6's with this saw, or is there a technique for cutting both sides of a wide plank in a way that lines up perfectly? I'm leaning toward "no" but thought I'd ask.
Thanks
Old 12-02-08, 06:50 PM
clockdaddy's Avatar
Typically most construction trim people will use a 14" miter saw that slides very much like a radial arm saw.
CD
Old 12-03-08, 04:16 AM
A miter saw is for cross cutting, not ripping. For ripping you need a table saw or radial arm saw. And for quality precision work a cabinet saw is best, but not easily moved and expensive. There are a number of more portable table saws available for jobsite work, that work fairly well for precision work, and won't bust the budget.
Old 12-03-08, 07:06 AM
mikeTN's Avatar
Received 1 Upvote on 1 Post
Exclamation
Thanks
You are right. The answer is no. You should always buy the best tools that you can afford. In this case you need at least a 12" compound miter saw. Anything bigger is better.
Old 12-03-08, 10:18 AM
C
Received 351 Upvotes on 294 Posts
Actually the answer is yes. I "survived".with a 10" Craftsman miter saw for a lot of years. Posters are correct about a sliding miter saw being the best for this work, but sometimes you have to make do with what you have. Your saw can cut up to 2X8s. A pain in the butt on a jobsite where time is money, but no big deal on a DIY project. If you have a lot of dimensional lumber to cut, you might consider buying a circular saw.
It's important to have solid work support on both ends of the miter saw. They need to extend out at least as long as your workpieces. To cut a 2X6 just cut the piece to the limit of the saw, lift the blade out and flip the workpiece. Obviously alignment is important to get a good cut. You can sometimes use stops to get perfect alignment, but a laser also does a good job.
Old 12-03-08, 02:43 PM
Received 1,289 Upvotes on 1,227 Posts
You just came up with justification for a 12" slider.
And, of course, maybe a table saw as well.
Old 12-03-08, 03:39 PM
C
Thanks to all
After checking out Home Depot for something COMPLETELY unrelated, I wandered into the tool dept. and found a very similar Ryobi Mitre saw that has sliders...about $100 more but seems worth it, so I'm boxing up my first one and moving on to the slider.
Thanks for the input, and I agree that I should try and buy the best tool I can afford. Cheers.
Old 12-04-08, 07:07 AM
mikeTN's Avatar
Cool
I too have survived with a 10" miter saw, but the key word was PERFECT!.I have done a lot of things without the proper tools, but I have also been doing it for a LONG time. It is not the TOOLS that make the craftsman, but the versatility!
