waxing polyurethane finishes
Old 11-21-00, 05:01 PM
Guest
Exclamation
A little helper of mine ran a fine piece of steel wool over a piece of furniture with a polyurethane finish, leaving light scratches behind! Do I have to put another coat of poly on, or can I wax them out? If I can use wax, what kind should I use?
Old 11-22-00, 03:50 PM
George's Avatar
Post
Poly:
Sorry, but wax won't do it - you need to apply another coat of finish,
George T.
Old 11-24-00, 04:43 PM
Guest
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by George:
Poly:Thanks for the info. I'm not really great at applying polyurethane. I usually end up with it not leveling well (pooling, etc.). Have you ever used wipe-on poly, and is it more easily controled as a refresher or final coat?? Thanks!
George T.
<HR></BLOCKQUOTE>
Old 11-24-00, 06:21 PM
George's Avatar
Post
Wipe on poly's only drawback is a lack of thickness in the coat, but for your paplication you don't need much.
Just sand out the scratches (240 grit wet/dry paper), scuff the rest of the top and have at it.
Another alternative (after the initial prep) is an aerosol.
George T.
