fix cabinet drawer bottoms
Old 03-23-09, 01:28 PM
What is the best material to use to replace kitchen cabinet drawer bottoms? I can slide the old ones out of the drawer after removing som staples.
Old 03-23-09, 02:13 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Most are something like 1/8" plywood or hardboard. If it has side mount slides, hot gluing a reinforcement bracket under the bottom could help. I've done that with furniture drawers, not kitchen cabinets.
Old 03-24-09, 04:58 AM
George's Avatar
Check the size of the grooves. If they're 1/4", I'd suggest masonite, which can be painted before installation. (it usually comes dark brown).
If the slot is large enough to accomodate this, it will give a very strong bottom - much less likely to bend or collapse.
