exterior stain on interior project
Old 04-15-09, 05:37 PM
T
Can a exterior stain be used on kitchen cabinets
Old 04-16-09, 03:47 AM
Received 871 Upvotes on 762 Posts
Welcome to the forums!
It's best to use a penetrating stain which is meant to have the excess [what isn't obsorbed by the wood] wiped off. Once dry, several coats of poly or varnish are applied to protect the stain and the cabinet.
Even if you wiped off the excess, an exterior stain would try to repell the poly/varnish preventing a good bond.
Old 04-16-09, 05:38 AM
Z
just curious why you want to use exterior stain on the cabinets?
Old 04-18-09, 04:21 PM
T
more colors are availible
Old 04-19-09, 04:29 AM
What color are you wanting to use?
Your local paint store should be able to mix up most any color interior stain you want.
