How to finish a wood sink? any thoughts?
Old 05-10-09, 12:04 AM
A
I just had a farmhouse style kitchen sink made for me out of african mahogony. The creator didn't put any finish on it to keep my costs down. My neighbor is a painter/wood finisher and will help me out with that. I thought i'd come on here and see if anyone has any suggestions for a product to use to finish it. I'd like the wood to be natural color. Waterproof is obviously a concern as well as also being safe to use with food items.
any general thoughts on a wooden kitchen sink are also welcome.
Old 05-10-09, 04:32 AM
Received 875 Upvotes on 766 Posts
Do you mean the sink cabinet? or is the bowl/tub itself made of wood?
Old 05-11-09, 11:07 PM
A
The bowl itself. I know it might not be the best idea ever
Old 05-12-09, 04:09 AM
I don't know what would be the best type of coating to use..... but whatever you use, it will need recoating every so often.
Old 05-12-09, 12:41 PM
A
yeah, i agree it will need service... any other ideas how to finish it?
Old 05-12-09, 12:50 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
I'd suggest just contacting a few of the companies that show up in a google search for "wooden sinks". Some say they just use coats of varnish. I would think something like used on boats would be the best.
Hope it was kiln dried before carving..I'd think it would crack/split like crazy otherwise.
Old 05-12-09, 01:27 PM
B
Received 47 Upvotes on 43 Posts
Similar problem with butcher blocks and wood salad bowls. Do a search for food grade mineral oils. You can re-apply them as needed and they should keep it from drying out.
Bud
Old 05-12-09, 02:09 PM
I was thinking that some type of oil would be the way to go. A marine varnish/poly would repell water well but I suspect it would be a nightmare once it started to fail.
Old 05-12-09, 02:38 PM
Gunguy45's Avatar
Super Moderator
Yeah, I know...2 or 3 diff sites that I checked..some said they used some sort of impregnated finish, couple said varnish, one said oil for maintenance.
Wooden sinks (esp a kitchen sink in a modern home) just seems like a bad idea. I saw plenty of wooden bowls used as sinks in Africa and South America... but that was just for quick washups.
