Sticky Stain - NEED HELP!
Old 06-29-10, 07:50 AM
Hello,
My wife and I recently purchased a 100 yr old home which still had all the original moldings. To try and clean and brighting them up we had the brillant idea off going over them with a light coat of stain. We did not sand anything first which I am now learning was our first mistake.
It has been a couple of days now and everything still very sticky. What can we do to fix this?
Old 06-29-10, 09:09 AM
Received 875 Upvotes on 766 Posts
As I'm sure you now know - stain is to be applied to raw wood. It dries in part by being absorbed by the wood.
IMO your best bet would be to scrub off the stain with a wet thinner rag. Be sure to use fresh air ventilation and dispose of the rags properly [not inside!]
Once you've removed the stain, the trim will probably look a little better than before you applied it but we can help you figure out the best plan plan of attack to rejuvenate the woodwork.
