Correcting bowed table top by sanding
I inherited an antique, oak, drop leaf table. The top, consisting of four tongue and groved boards, is bowed, the leaves are in good condition. I tried to remove the bow using "the wet one side and dry out the other side" method. Because I planned to use it always in its extended position, I finally screwed all the top and the leaves to an underneath board to try to keep it from bowing again. No luck. Today, I talked with a professional furniture restorer who would charge $625 to sand the top and join the top with the legs using biscuts before refinishing. Although the table is an antique, I do not care about perserving value. I just want it to be functional and nice looking.
I am willing to try to sand the top flat using my orbital sander. Any tips? If I sand down the top will I ever get the finish color to match the leaves?
Any comments on the feasisbilty of my attaching the top to the leaves using just glue and a rope to hold the glued pieces together. Clamping is going to be difficult because of the curved edged leaves (and I do not have any big clamps).
Could you post a few pictures of this top.....from the top, side and end so we can see the extent of bowing? http://forum.doityourself.com/electr...your-post.html Thanks.
