Tips for Sanding and Refinishing Stair Balusters and Railing
Old 05-11-12, 07:22 AM
D
Hi All -
I recently installed new hardwood flooring with a beautiful Gunstock finish. The house had carpeting and oak stair railing with white spindles. I want to stain the stair railing and balusters to match the flooring, and then install wrought iron spindles.
My question is this: Any tips for sanding the balusters and railing? There are lots of details and turns on the wood, so I would appreciate any tips from the group on making this look as good as possible!
Also, if anyone has any tips on good wrought iron spindles, I'd appreciate that as well - saw an interesting product at Lowe's, but it's $11 per unit for the spindle and attachment system, and I have 75 to do!
Thanks in advance!
Old 05-11-12, 09:13 AM
Received 871 Upvotes on 762 Posts
Welcome to the forums!
I assume these stair parts currently have a finish on them ?? What color are they? darker, lighter or totally different? Maybe a few pics showing both - http://www.doityourself.com/forum/el...-pictures.html
Basically you start out with a coarse grit and work your way to a finer grit. Always sand with the direction of the grain. Cross sanding leaves scratches in the wood that will be noticeable once the stain is applied..... and they're hard to sand out Sometimes a sharp scraper is beneficial in corners and other hard to get places.
