What is this corner hardware for a bookcase called?
Old 05-16-12, 06:48 PM
K
Hello All,
What is this corner piece, common on wood+metal bookcases, called? See picture- it holds the metal of the bookcase together at right angles in 3 dimensions, and is decoratively shaped.
Can you tell me where to get something like it too? My searches for "corner bracket" are too vague to be helpful.
It involves metal but I chose this forum category anyway because of it's focus on furniture, so thanks for any help!
-Kris
Old 05-16-12, 07:16 PM
XSleeper's Avatar
Received 1,963 Upvotes on 1,760 Posts
Good luck finding something exactly the same. The only thing I can find that is remotely close to that is a Simpson Strong tie connector called a RTC22 or RTC24.
Old 05-17-12, 06:14 AM
K
@xsleeper, thanks for the suggestion!
If anyone knows of something more of a vintage style, that'd be a great help.
Old 05-17-12, 07:17 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
If you just need a few...a sheetmetal fabricator could probably whip them up in an hour.
Draw one out to scale on some cardboard stock take it to a few places, see what they say.
If it's a real complicated pattern, they'd probably have to cut them out using a plasma cutter or waterjet...which would be more expensive.
