Office Chair Plywood Questions
Old 11-18-12, 05:59 PM
D
I removed the seat of an office chair and took off the plastic underneath, the fabric, and the foam. On the underside of the plywood I see all these brown spots. Is this likely mold? What would be the best way to kill/treat it?
Also, if I want to just build a new piece, what's the best way to curve a new piece of plywood into a similar shape? What are these metal pieces called that go into the wood and hold a bolt coming from the base? Do I just drill a hole and then hammer those in?
Old 11-18-12, 06:15 PM
Received 4,093 Upvotes on 3,676 Posts
Yup.....and they're called tee-nuts.
Old 11-19-12, 03:44 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Make sure you hammer them in from the opposite side as the pull.........but you knew that.
Old 11-19-12, 04:28 AM
T
Those seat panels are glued up layer by layer and molded in a press. It can be done in a home workshop by an experienced woodworker working on a fine piece but it's not worth the time and effort to repair an office chair. I don't know if that is mold, it could be glue bleed through from the molding process.
