Refinishing wood table end
Old 05-16-13, 02:45 PM
B
Can I remove the stain from the my refinishing wood table end and I will put the new stains on again? Can I use minmax oil modified polyurethane clear gloss on it ? Thanks
Old 05-16-13, 02:56 PM
Received 1 Upvote on 1 Post
Confusing post, refinishing wood table end, no clue what that means.
If your trying to change the color of the stain under a sealed surface your going to have to sand it back to bare wood and start over.
No one here knows with what your working on since there is no picture.
Is this a veneered piece of furniture?
Do you really mean it's an end table, not wood table table end?
Old 05-17-13, 04:02 AM
Received 850 Upvotes on 746 Posts
As Joe said, we need some clarification as to what you are working on and wanting to do. Pics might help http://www.doityourself.com/forum/el...-pictures.html
As noted, stain only works on raw wood. It can be difficult to completely remove all of the existing finish by sanding only. Often it's best to remove the majority with a chemical stripper and then finish with sanding.
Old 06-14-13, 02:45 AM
Post a picture Paul, also on any DIY site it's best to add your own post not just hijack someone elses.
