Going to open up the back of my kitchen cabinet, thought I would ask first...
before I CUT...
I have a problem with my kitchen sink in that the drain stubout inside the cabinet is too high.
It used to be OK.
But then a garbage disposer was added by someone. That lowered everything.
So the p-trap is not working very well. The outlet of the disposer is actually a good two inches below the drain stub out.
I would like to lower the drain there by say 3".
Which means I need to open the back of the cabinet, and enlarge that hole until I find where it connects to the vent, then lower the tie in. Judging from the vent that comes out on the roof, I believe I might have to open up a hole about 24"W x 28"H.
Let's say I get all this done, how would I go about mending the cabinet and fix the big hole?
It used to be OK.
Well, you would get some 1/4" plywood and piece it in around the pipes as best you can but reworking the drainage is a lot of work to be doing while laying inside a cabinet under a sink. If it was me, but it is not me, I would remove the disposal. I never saw the point of those things anyway.
Please post well lit pictures of the plumbing under your sink. Lots I've worked on looked like they were done by the plumbing challenged. We may be able to give you a better solution. http://www.doityourself.com/forum/li...-pictures.html
