Making clean, accurate notch in lacquer finished cabinet?
Without getting into the long story of why (big discussion with my cabinet maker.. he thought it was too risky), I need to route several rectangular notches about 3/4 deep, 3 in long and 2 in wide without disturbing the lacquer finish around it. This is maple wood with a white lacquer. My idea is to first score the outside with a sharp wood chisel, and then use a smaller router to make the notches, and then use a chisel again to remove the rounded inside corners. We are both afraid that the router machine might be hard to control when it grabs the wood. So we would make a custom jig first. Is this the best way or is there a better technique or set of tools?
The router idea is good, but I suggest you make a template and use a "flush trim pattern bit" (google it) in the router. That way you can fully control the machine and no scoring needed. Just be sure to do a test run. Clean the corners as you mentioned.
I had the same thought as Mark about a utility knife for scoring instead of a chisel.
I also think I'd practice the whole process on some scrap first.
