Countersinking
Old 10-26-13, 08:38 PM
A
Countersinking
What's the norm on countersinking screws? Countersink then drill the hole/pilot hole or drill the hole then countersink with a countersink bit?
Old 10-26-13, 08:42 PM
Received 1,109 Votes on 1,029 Posts
I usually drill the hole first and then countersink it.
Old 10-26-13, 08:43 PM
XSleeper's Avatar
Received 667 Votes on 617 Posts
Use a countersink that comes with a pilot drill bit?
image credit: amazon dot com
Old 10-26-13, 08:55 PM
A
That's what I usually do but I came across a few videos online where they countersunk first then drill the hole
Old 10-26-13, 08:59 PM
A
What about boring a hole? Which comes first?
Old 10-26-13, 09:36 PM
You lost me..... I thought boring and drilling are the same thing.
Old 10-26-13, 10:02 PM
A
With foster drill bits!! Just adding characters so I can get the 25 character minimum lenght
Old 10-26-13, 10:18 PM
You mean forstner bits?
With a bit like that you would have to bore/drill the hole first.
Old 10-27-13, 12:08 AM
F
Received 35 Votes on 27 Posts
If you are in need of a counterbore (stepped hole) with a Forstner (always capitalized) bit then the larger hole is drilled first. When using a standard countersink always drill the pilot hole first because the very tip of the countersink doesn't have any cutting edge and will heat up quickly.
Old 10-27-13, 08:25 PM
A
Damn Johnnie Walker Thanks all at least now I can set myself a standard
