What Can I Use to Seal and Protect Countertops?
Received 0 Votes
I purchased a product called instant granite (Instant Granite - Instant Granite Film for Countertops, Faux Granite Film, Peel and Stick Granite Film. - Give Your Countertops an Extreme Makeover!) and I installed it over laminate countertops in my kitchen. I am pleased with the results so far.
I want to seal/protect the faux granite treatment. What type of product can I use? Can I use oil based or water based polyurethane? varnish?
Is there something that is water proof, heat resistant and scratch resistant?
How many coats do you suggest?
How long would I need to let it dry?
Can/Should I sand this material before I apply a sealant?
Would Envirotex Lite work? I am not sure how much I would need or how expensive it is.
Thank you for your help.
Have you tried contacting the manufacture and asking them? Oil base poly/varnish often changes the color of what it's applied too - usually gives it an amber tint.
Received 0 Votes
Hi Marksr:
Yes, I contacted the manufacturer, this was the response I got-
I have had others apply a poly coating over the granite for extra durability. Seems like it works well. Thanks!
I followed up by asking whether a poly coating was a water based polyurethane or an oil based polyurethane, but I have not received a response to that question.
Based on the response I did get, what brand of coating do you think was being referred to?
Oil base polys tend to adhere better than water based but there is a chance that the oils could be detrimental to the film you applied. There generally isn't a big difference between brands. Hopefully the manufacture will get back to you with more details.
