Noisy Rocking Recliner
Old 02-21-15, 02:48 PM
E
My wife's rocking leather recliner emits multiple "clicks" from its wooden rocking components. Is there some substance that I can apply to the under works to stop or at least lessen the incessant clicks?
Old 02-21-15, 03:47 PM
P
Temporarily Suspended
Can you pinpoint the exact location? I don't think that a spray would help a click but if you want to take a chance, you could try some white grease. That's available in a spray. Don't waste your time with WD40.
Old 02-21-15, 04:03 PM
E
Can't exactly pinpoint the problem areas. Should I simply ask for white grease spray or a particular brand? Thank you.
Old 02-21-15, 06:22 PM
P
Why don't you flip the chair upside down & take a look at it? Then decide if the grease might work.
Old 02-21-15, 07:15 PM
E
Okay, I flip the rocker over and have a look. How do I determine if grease will work?
Old 02-21-15, 08:45 PM
P
Try to determine if the clicking is caused by 2 pieces of metal hitting each other. If one was bent for some reason, it may have to be put back in place or replaced completely. In that case, grease may not help. Another possibility is that something could be digging into the wood. Look around, you'll find it.
Old 02-22-15, 05:06 AM
E
Will examine thoroghly. Thank you.
