Squaring off a router plunge cut
Old 10-04-15, 10:12 AM
Hi All,
I am working on a project and need to have a square cut in the middle of wood rather than a rounded edge halfmoon cut (see picture). Is there a router bit that would allow me to do this?
Basically I want the end of this router cut to be square and not circular.
Thanks so much!
JonName:  Router Cut.jpg
Old 10-04-15, 10:18 AM
Received 860 Upvotes on 752 Posts
Use a sharp chisel. Nothing that rotates in a circular motion can make a square end to the groove.
Old 10-04-15, 11:00 AM
G
Received 2 Upvotes on 2 Posts
^^^ Except a hollow chisel mortiser for some big bucks.
Old 10-04-15, 11:45 AM
ray2047's Avatar
You can use a squaring chisel. Imagine a chisel with an "L" shaped end instead of flat.
Example:
::: FORTUNE EXTENDABLES CORP - Magnetic Squaring Chisels (CNCS) :::
Old 10-05-15, 06:49 AM
G
You hammer the chisel down and lever out the waste. Regular (thin) chisels can be used if you take small cuts. The final blows are a light cut with the bevel facing the slot that leaves a square end without crushing the wood fibers on the shoulder.
If that's the mortise end of a hidden joint, many builders find it easier to trim or sand the tenon round to match--rather than try to chisel the corners of the mortise.
The tool Ray shows is great for shallow mortises like locksets, hinges and door strike plates.
