Can I use bounty paper towel for oil stain on wood working?
Old 01-04-16, 01:22 PM
Q
Received 1 Upvote on 1 Post
Hello all,
I have Bounty« paper towels are 2X more absorbent.
Can i use those paper towel to remove/wipe off the extra oil stain when I do wood stain finishing?
Thank you
Old 01-04-16, 01:25 PM
Received 4,049 Upvotes on 3,632 Posts
No old T'shirts or old underwear around ?
Old 01-04-16, 01:26 PM
Received 851 Upvotes on 747 Posts
Possibly but I'd be concerned that the paper towel will disintegrate some and leave 'lint' on the stained wood. IMO old T shirts make great stain rags .... or any similar material.
Old 01-04-16, 01:36 PM
Q
Hello all,
I saw this tutorial https://www.youtube.com/watch?v=qUgZefTPESQ which uses Scott Model # 75143Shop Towels and I cannot find it on local HD.
I will keep using old t-shirt.
Thank you
Old 01-04-16, 01:39 PM
While I didn't take the time to watch that video, I wouldn't put a lot of stock into many of the self help vids on the net. Many are done by those without a clue No matter what the project it doesn't hurt to double check here as there is usually someone around that has first hand experience on doing the job correctly.
Old 01-04-16, 01:56 PM
Received 1,273 Upvotes on 1,213 Posts
I've applied oil based polyurethane with a paper towel before and it worked just fine.
Not exactly the same as what you're proposing....
Old 01-04-16, 02:53 PM
The shop towels are a more rugged paper towel.... almost like a roll of pull out rags. There isn't much lint that comes off of them. Depot would have these......Scott 200-ct Rags in a Box- The Home Depot
Old 01-05-16, 02:51 AM
Probably out to state a reminder that whatever type of rag is used to wipe stain - it must be disposed of properly as they oil stain makes them highly combustible! Most common way to store them until disposal is to put them in a metal container with a lid .... a bucket of water also works.
