What are these defects in my Polyurethane?
Old 09-15-16, 12:57 AM
Hello all.
I'm getting defects in my coats but they are not dust or debris from the air.
It happens when ever using a brush even a fine varnish brush I get these types of defects in my coatings. I think it's just the nature of using a brush & can't be avoided. I have tried thinning my clear a bit but they still form to some degree.
Here are some pictures I took to show what I mean.
After coat dries there is fine dust like defects.
After a moderate sand you can see these defects go deep into coat.
They always have a round base shape to them.
Just curious as to what these are & how to reduce them.
thank you.
Old 09-15-16, 03:30 AM
Received 426 Votes on 381 Posts
The 1st pic looks like air bubbles in the poly. Poly/varnish should never be shook, only stirred and not aggressively.
Old 09-15-16, 07:07 AM
Received 98 Votes on 86 Posts
Do you know what tipping-off is?
Old 09-16-16, 12:18 AM
Hi marksr,
I can't avoid these I never shake my cans & when I pour a small amount into a see through container I let it sit for a while & there is no air bubbles in it.
Is this just what brushes do?
thanks
Old 09-16-16, 12:22 AM
Hi stick****
I will read up on tipping off, I still have a lot to learn about varnish.
thanks
Old 09-16-16, 03:11 AM
They sure look like air bubbles. I suppose it's possible to introduce the air while you are brushing or loading the brush but I've never had that happen to me with a brush. Another possibility is a containment on the surface you are applying the poly to. You might try wiping the surface down with a clean rag damp with mineral spirits [paint thinner] prior to applying the poly.
Old 09-16-16, 05:10 AM
Is the wood red oak? If so, oak is a porous wood and unless you fill the pores first the poly kind of runs/sinks in to create this look. If you keep adding coats these will eventually fill in and you will get a smooth surface. It may take many coats.
Old 09-16-16, 05:22 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
I always use water based poly, 1st couple of coats I use 50 / 50 with water. It spreads easier and few defects (less sanding) Works with oil base but I hate cleaning brushes.
Old 09-16-16, 05:26 AM
The only times I've thinned poly/varnish 50% or more was when the wood needed a wash coat - similar to wood conditioner, prior to applying the stain. Thinning the poly a little [about 10%] does help it to flow and level off better.
