What can I do with 5mm "Triply"?
Old 09-16-17, 07:02 AM
Received 9 Upvotes on 7 Posts
When hurricane IRMA was approaching South Florida everyone was looking for plywood to cover their windows and local lumber stores and home improvement centers sold out of plywood quickly.
Lines were formed outside Home Depot over 100 long with wait time of 4-6 hours and a ration of maximum 10 sheets per vehicle (later on reduced to 5). I waited in line twice and it ran out before it got to me after 3 hours of wait.
With no other options I ended up getting those 4X8 sheets of really thin 5mm thick "TRIPLY" and used two of them for each window.
After the hurricane I have now oh about 50 full sheets of this stuff. About half of them are warped a little from the rain and the other half still straight. All of them have 1/4" holes drilled around the edges for Tapcon screws. Any idea what I can do with them? It seems a shame to throw them away...
One thought I have is I can take the straight ones and cut them into drawer sizes and put that into the bottom of the kitchen cabinets and drawers and use them as "liners"?
Any other ideas?
Old 09-16-17, 08:54 AM
Received 4,101 Upvotes on 3,683 Posts
I had to look it up as I didn't recognize the name.
Old 09-16-17, 09:04 AM
its not poly it's real thin plywood kind of finished on both sides.
Old 09-16-17, 09:26 AM
I removed the plastic poly picture. It's basically a non void thin underlayment.
Old 09-16-17, 10:31 AM
H
Received 297 Upvotes on 255 Posts
If they're already drilled to fit, I'd glue them together in pairs with construction glue, set aside for next time.
For the warped ones, stack a few on a flat surface like a concrete garage floor, set pieces of 1/2" plywood over them and park the car on em for a few days.
Old 09-16-17, 10:44 AM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
IF you look at the edge of the plywood you will see it is made up of 3 layers. Tri-ply.
Save for the next one?
Old 09-16-17, 11:04 AM
The name triply is used for many products but it's a registered poly product trademark.
Old 09-16-17, 11:48 AM
ray2047's Avatar
Why not save it for the next storm?
Old 09-16-17, 12:26 PM
I cannot use it for the next storm.
First reason is this is too thin. Even when I double it up it is not stiff enough. If there is a next storm I would still try and get at least 5/8" plywood.
Second reason is even if I wanted to I couldn't. The Triply was attached to the masonry block wall with Tapcon screws. As you know Tapcon is single use. If you drill a 3/16" hole for a 1/4" Tapcon once the screws are driven into and backed out the same holes cannot be reused. If I were to use these Triply again for another storm I have to drill all new holes anyways.
Finally I am seriously considering getting the accordian style shutters - I am getting too old to be hunting, moving and putting up plywood in the rain.
Old 09-16-17, 12:30 PM
Just to clarify the sheets I am referring to as TRIPLY is this.
Tri-PLY 1/4 in. x 4 ft. x 4 ft. Birch Underlayment (Actual: 0.196 in. x 47.75 in. x 47.75 in.)-448887 - The Home Depot
Old 09-16-17, 01:31 PM
H
Well, lots of plywood reindeer? Five sets of all 8 reindeer plus a sleigh, and Santa
Or, lots of glue, and lots of clamping..
Plywood Projects - by DaveGlx @ LumberJocks.com ~ woodworking community
Old 09-16-17, 01:34 PM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
Put a for sale sign on it. Charge about half what it cost you and recoup some of your money.
I would've called that stuff luan plywood underlayment.
Old 09-16-17, 04:58 PM
D
Donate, take a tax write-off
Maybe Habitat For Humanity or a veteran's assistance organization can use them...
Old 09-16-17, 06:01 PM
Luan plywood is not void free between the outer sheets like this stuff is.
