How secure 2x4 legs to plywood?
Old 11-12-17, 10:33 PM
I have a plywood table top and I want to use some 2x4s as the legs. How can I secure the 2x4s to the plywood so that it's solid?
Old 11-13-17, 03:43 AM
I'd install a 2x6 [on edge] around the perimeter of the underside of the top and then secure the legs to both the top and the 2x6.
Old 11-13-17, 07:39 AM
Secure the legs on the inside corners of the 2x6?
And the 2x6 vertical or flat on the plywood?
Old 11-13-17, 08:12 AM
The 2x6 would be vertical. That both gives you more area to secure the leg and makes the top stiffer.
Old 11-13-17, 09:14 AM
Handyone's Avatar
The vertical 1x6 or 2x6 is called an apron.
Check out these table top fasteners, they are a good way to attach the top to the apron.
You will need a table saw or router to cut a 3/32" groove in the apron.
Table Top Fasteners (8/pack) | Rockler Woodworking and Hardware
