Spots on the wood tables
Old 06-15-18, 08:17 AM
I stained two wood tables and used miniwax polyurethane clear glossy but I saw lot of spots on the wood tables. I removed the clear glossy and I stained them again. What do you suggest because I won't use Polyurethane anymore?
Old 06-15-18, 09:12 AM
G
Received 2 Upvotes on 2 Posts
Are you referring to the blotchy stain and what looks to be a water ring under the finish? Not the fault of the finish, but gloss anything will amplify any faults.
Uneven staining can be caused by many things. A particularly annoying one is contamination of the wood from the use of polish or other products that contain silicone. If your table's original finish was tired & you used a quick-shine product like Pledge on it, some may have seeped through & into the wood itself.
Old 06-15-18, 10:11 AM
Received 1,273 Upvotes on 1,213 Posts
I am always amused watching a baseball game and seeing a batter swing and miss and then look at his bat like somehow it was the bat's fault.
I think this is the same situation only you're looking at the poly.
Old 06-15-18, 10:35 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Looks like the wood needs to be sanded and re stained.
Stay away from Mimwax, the stain is ok but the top coats are krap.
An excellent finish is Old Masters water based urethane, Naturally costs more but results are perfect!
Old 06-15-18, 10:47 AM
XSleeper's Avatar
Received 1,940 Upvotes on 1,742 Posts
I imagine those spots and stains were on there before you used the polyurethane.
