Refinishing a pine farm table 8’
Old 08-05-18, 11:19 AM
I am working on a table that has several cracks unevenly the whole way down table also has a uneven wave down table. New to forum Appreciate any Ideas. Especially on the uneven part of it .
Old 08-05-18, 04:15 PM
P
Received 914 Votes on 841 Posts
You can sand or plane it.
Old 08-06-18, 02:22 AM
Received 408 Votes on 364 Posts
As PD stated, sanding or maybe planing is the only way to make the top level. Cracks can be filled but it isn't always wise to do so. Pics might alter our advice some - https://www.doityourself.com/forum/e...-pictures.html
btw - welcome to the forums!
Old 08-06-18, 07:43 AM
Received 104 Votes on 91 Posts
If you can post that picture please make sure to also post one of the underside of the table.
Need to see what type of support they used to hold the boards together.
No way would I use a filler to fill the gaps!
What I've done before is fill the gaps with Tite Bond II glue and used pipe clamps to pull it back together, then added 1 X 4 strips of wood to the underside with clearance and counter sunk holes predrilled to hold it all in place.
Make sure to get the extra glue off ASAP to reduce the chance of staining.
Old 08-06-18, 10:06 AM
Not sure how to add a pic on here what am I missing? Thanks
Old 08-06-18, 10:35 AM
XSleeper's Avatar
Received 945 Votes on 863 Posts
Follow the link marksr posted. The instructions are pretty clear.
