zero clearance hinges for cabinet
Old 08-10-18, 02:21 PM
P
Received 11 Votes on 11 Posts
Thanks in advance. Here is my problem. I am replacing the cabinet doors with home made doors. The old doors (it is a 2 door face frame cabinet) had a 3/8 overlay so I made the new ones the same. so far so good. I made slide out shelves to go inside which is where the problem arises. I left 1/8 inch clearance on each side of the shelf. I bought the "
3/8" Blum® Compact Soft-Close BLUMotion Overlay Hinge" which requires at least 1/4 clearance on the side. I rebuilt one shelf but I really hate to do the others as I am wasting so much effort on that.
Is there another hinge that you know of that will allow a 3/8 overlay with the door fully clearing the opening when open?
pictures available if needed.
- Peter
Old 08-10-18, 04:19 PM
XSleeper's Avatar
Received 997 Votes on 908 Posts
No cup hinge will. Only the old style variable overlay ones will.
like these.
But if you have 3/8 overlay and your door is 3/4 thick, the door will be in the way by 3/8 when it's open at a 90. Should have used 3/4 overlay and built the drawers smaller it seems to me.
