Gluing
Old 05-23-01, 03:38 PM
Guest
Cool
What kind of glue is good to repair chairs with?
I have used a glue made by Zap bought from Masters
but i have lost the info to buy more, it was a glue with
a activator to help it set up quicker.HELP...............
Thanks
Old 05-24-01, 02:19 PM
fewalt's Avatar
Floyd,
A yellow wood glue is best for repairing wooden chairs.
There is also one called Gorilla glue, this is good also.
It is best, in the case of rungs, etc. to remove the loose part completely and sand off all previous glue before re-assembly. The yellow glues are water-based which will swell the wood after applying and form a good joint. After glueing it is also best to apply clamps or a ratchet strap until the glue is dry, usually overnight.
fred
Old 05-24-01, 06:20 PM
George's Avatar
Floyd:
Fred has given you some good advice. The only difference between his technique and mine is that I usually scrape the glue off the stretchjer tenons instead of sanding - but that's just because I'm cheap and sandpaper costs money!!!
BTW - you can get ZAP at the following web site if you really want to use it.
http://www.modeltool.com
